Tricks to getting oil pump pickup in?
Feel dumb asking this... I've installed oil pump pickups before, basically a crescent wrench over the shoulder on the pickup tube and whack it in- but the one for my 455 isn't budging- and the wrench is starting to dig into the shoulder on the pipe...
I even tried sticking it in the freezer for an hour first- can't get it more than a 1/4" in
Any tips?
This is a melling standard volume pump & pickup.
thanks
Any tips?
thanks
There may be a burr in either the casting of the pump or on the pick up. I had the same issue on my last 403 build. I had to use a little emery paper on the pickup, and some 3 in 1 oil on the tube before I tapped it in. Then I used the wrench, just like you did to tap it in place. Come to find out, the way the pump was cast, the pickup did have a little space between the pump and the knurl on the pickup.
I'm sure you have done it a dozen or more times, but make sure the pickup is going in perfectly straight, and rotate the wrench as you tap it into place.
hope that helps a little.
John
John
De burr the inlet of the pump housing with some sand paper and clean it . The sand the pipe that goes in. Then apply some grease or cam break in lube and work it in. I had this happen to me as well.
