toro oil pan question
I did this same thing many, many years ago on my '70 442, and I think the only mod was to use the Toro oil pump and pickup, as the pan is deeper by one quart. I don't recall what I did for the bump in the pan that holds oil in the front half, as the Toro pan has clearance for steering linkage not on the 442...sorry?
You just need to also install the oil baffle in side the pan. As far as the front bump, it only holds about 1/4 of a quart. In the old days, nobody worried about that little amount of old oil left when changing the oil.
I flattened it with a rosebud tip in an oxyacetylene torch, large diameter pipe with hammer to get a fairly smooth shape. As above, since it doesn't have a sump baffle, you should use the factory baffle that bolts to the block with main cap bolts that have studs on the heads.
