Toro 455 Oil Deflectors
Old Mar 10, 2009 | 07:07 PM
sklbndt's Avatar
I am using a 69 Toro 455 in my cutlass and will be installing the correct oil pan for my car. Does anyone know if I need to remove the oil deflectors or should I just leave them there? Also, while inspecting the timing set I noticed the oil slinger was cracked and I can't seem to find a supplier. Thanks in advance!!
Old Mar 11, 2009 | 10:15 AM
I'm not sure the Toro deflectors will fit in the RWD pan. The Toro pan does fit in the A-body chassis, however I don't believe it's as good as some folks think it is. THere is a modest increase in oil volume, however the double hump design traps some oil.
oldspackrat
Feb 7, 2015 10:09 PM
dnmfranco
Aug 5, 2014 06:16 PM
vistacruiser1971
Dec 27, 2012 07:35 AM
sethj78
Dec 21, 2011 03:51 PM
