Tips on pulling 68 rocket 400 mated to a th350/400
Old Apr 15, 2024 | 10:30 AM
d4nnyb0i's Avatar
Hey guys, this spring I’d like to pull the motor and trans on my 68 442, it’s been locked up since I pulled it out of the shed it had been sitting in since the 90’s and last fall I took the intake and heads(with exhaust manifolds attached) off of it. I would like to pull the motor and trans together but was wondering if the weight would be too much for a cherry picker, any advice would be appreciated!
Old Apr 15, 2024 | 11:31 AM
442Harv's Avatar
I always pull tran with engine, using a carb plate. You probably need a person to help. so you can tilt or lift it to get it in and out.
Old Apr 15, 2024 | 11:50 AM
Sorry, that would scare the crap out of me. Pulling the engine and trans together is common, but you need to use an engine tilter to get it at the correct angle to get it out of the car. This is a lot easier if the front end is off.
Old Apr 15, 2024 | 02:36 PM
d4nnyb0i's Avatar
would it be feasible to do it without a carb plate since I already have the heads and intake off of it and just use the old head bolts as anchor points? I’m willing to pull the motor without the trans attached I just really don’t want to put the heads and intake back on it
Old Apr 15, 2024 | 05:23 PM
Sugar Bear's Avatar
I wouldn't use head bolts. Consider putting a well secured sling under it.
Old Apr 15, 2024 | 05:29 PM
Why not? They are the strongest fasteners on the topside of the motor. And since the engine/trans needs to be tilted at a large angle, slings are the least secure way to do that.
Why are we reinventing this. Get a engine tilter. Done.
Old Apr 15, 2024 | 05:50 PM
Sugar Bear's Avatar
"Why not?"
The OP stated the heads are off and asked about using the old head bolts. About 3 inches of the bolt will be sticking out pulling inward bending the bolt with no clamping force. This will be the weight of the block and the transmission together.
I do agree about not using a sling due to the angle.
Old Apr 15, 2024 | 06:01 PM
"Why not?"
A spacer between the bolt head and the chain solves that problem. Alternately, shorter Grade 8 bolts also work.
Old Apr 15, 2024 | 06:09 PM
d4nnyb0i's Avatar
"Why not?"
i do have an engine tilter to go with my cherry picker, would shims of some kind (perhaps old deep sockets) to snug down the chains onto the headbolts to make this a slightly better idea? like i said before im willing to pull the motor and trans separately to prevent the bolts from bending/snapping
Old Apr 15, 2024 | 06:15 PM
d4nnyb0i's Avatar
i had about the same idea for spacers to prevent bending, i've never pulled a motor before so i want to try and do this the best i can by myself. would it be easier to just pull the trans and motor separately since im going to be doing it by myself?
Old Apr 15, 2024 | 06:32 PM
Sockets are exactly what I've used before. The important thing is that the chain needs to be directly against the block. Do not impart any bending loads into the bolts. It might be prudent to just get some Gr 8 bolts of the correct length for this. Those of us who have been doing this for a while have coffee cans full of those.
Old Apr 15, 2024 | 07:14 PM
Sugar Bear's Avatar
Yes it does, details.
JIM'S w30
May 4, 2020 03:30 PM
BigMike65
May 14, 2019 06:26 PM
ros6872
Feb 4, 2016 05:51 AM
ctrain22
Jul 7, 2009 06:06 PM
olds4life
Mar 31, 2008 07:28 PM
