Stupid question on distributor timing
Old Mar 5, 2014 | 09:15 AM
waterzap's Avatar
This might be a silly question, but on the distributor, which is the number one cylinder? Or rather, which two cylinders flank the little dwell flap? Then I can work out where the other ones are on a 67 toronado 425. Guess all the olds engines would be the same. Just did my intake manfold gasket…again. This time did not use the rubber strips they gave me with the kit. Last time they got pressed out on the sides. Engine leaked oil and ran terribly.
Took photos of the position of the rotor and distributor, but forgot to make a mark on the distributor cap for the number one cylinder.
Old Mar 5, 2014 | 09:54 AM
1970cs's Avatar
Lansing built
Just to make sure it's timed correctly, I will cheat instead of typing and use the tutorial on line.
http://www.junkyardgenius.com/ignition/dist01.html
Pat
Old Mar 5, 2014 | 10:03 AM
And I'll add this pic.
Old Mar 5, 2014 | 10:05 AM
waterzap's Avatar
Very good. Thank you. Will turn the harmonic balancer to TDC, and make sure the rotor points to the number one on the pic.
Old Mar 5, 2014 | 10:53 AM
boese1978's Avatar
Need to make sure the # 1 cylinder is on the compression stroke of course.....
auto_editor
Apr 26, 2013 05:19 PM
MDchanic
Mar 27, 2012 07:54 PM
Tedd Thompson
Sep 24, 2010 07:32 AM
gearheads78
Dec 18, 2009 06:15 AM
442scotty
May 13, 2009 05:42 PM
