Std volume or high volume oil pump?
Old Apr 6, 2024 | 01:32 PM
PaulWinn's Avatar
Assembling by 455 this week finally
Previous owner had a Melling hv oil pump combined with a Moroso aftermarket 6 qt oil pan. I am going back with stock oil pan. Will the hv pump suck my oil pan dry? And it might be pertinent that my main bearing clearances are on the high side .0028 average.
Old Apr 6, 2024 | 03:16 PM
cutlassefi's Avatar
.0028 is NOT on the high side. I run .0032-.0035 on the mains 1-4 with no issues. You should be fine with an hv pump.
Old Apr 6, 2024 | 03:23 PM
The "suck the pan dry" myth is another that refuses to die.
Old Apr 6, 2024 | 06:13 PM
Andy's Avatar
Amazing how rumors on oil issues in Olds refuse to die..95% of classic car owners rarely hit 5500 rpm.
Old Apr 6, 2024 | 06:14 PM
Yup. And they MUST have four wheel disc brakes and rack and pinion steering and tubular control arms to drive the car to cruise night and back once a week.
Old Apr 6, 2024 | 06:15 PM
PaulWinn's Avatar
Sorry! It's my first BBO build, motor is so hard to get in and out I'd hate to do it twice
Old Apr 6, 2024 | 06:44 PM
Hey, I’m in the 5% club!
Old Apr 7, 2024 | 04:47 AM
Same here.
Old Apr 7, 2024 | 10:12 AM
With TH400, 3.42's, and 235/60/15's, my '67 is turning 3,100 RPMs at 70mph and it sounds like I'm inside a Rocket Ship (pun intended)! I can't even imagine running it at 5,000 RPMs!
Old Apr 7, 2024 | 11:16 AM
Andy's Avatar
Both my cars are four speeds and I run through the gears quite often shifting at 5500. That’s what they’re built for. That’s what I like to do.
Old Apr 7, 2024 | 10:34 PM
Pedal to the floor should result in a 1-2 shift at around 5000 RPM. Have you never done that?
Old Apr 8, 2024 | 06:18 AM
redoldsman's Avatar
Proud Viet Nam Veteran
You probably can't do that in a Cutlass Supreme since you can't get headers that fit. Just kidding. Another one of those old rumors.
Old Apr 8, 2024 | 06:41 AM
Kenneth - Yes I have, but less than a half dozen times. I have never had the car on a track or open lot where I felt like I could open it up and take my attention away from my driving to watch the Tach at the 1st shift point. When the hard shift occurs from 1st to 2nd the car gets real squirrelly because the tires start spinning so much faster it's all I can do to keep her going straight. As I told Andy in a PM yesterday, the shift point is probably close to or even above 5,000 RPM's, I just don't know.
Old Apr 8, 2024 | 07:29 AM
herkguy's Avatar
My HV pump came with two springs for the relief, one is for higher pressure which I installed.
it puts out 75-80 psi cold. It keeps me from getting on it until it’s warmed up though as a benefit…
I know some have just drilled a new hole for the retaining pin to increase spring pleasure also.
honestly I likely could have just used the regular one, but I am not disappointed in it’s pressure.
you likely will have good pressure with your clearance.
Maybe Mark would have some thoughts on the pressure springs.
Old Apr 8, 2024 | 02:02 PM
Bernhard's Avatar
Nice!
dieselolds81
Oct 31, 2023 11:29 AM
jskorz
Oct 9, 2021 12:55 PM
Cdub
Jul 2, 2016 06:29 AM
71cutlasssx
Nov 11, 2009 05:16 AM
68conv455
Dec 26, 2007 07:29 AM
