Spark Plugs
Old Aug 30, 2023 | 04:06 PM
Bigmikey65's Avatar
Spark Plugs
What is a good, quality Spark Plug replacement for AC R44S ? Engine is stock - ‘70 W30 4-Speed.
Old Aug 30, 2023 | 04:43 PM
442Harv's Avatar
I have a 70 W30, I use AC Rapid Fire plugs.
Old Aug 30, 2023 | 04:49 PM
You can cross reference that plug into another brand or go up 1 heat range to a 45
Old Aug 30, 2023 | 04:55 PM
66SportCoupe's Avatar
If you're not worried about being a show points car run NGK 3332 plugs
Old Aug 30, 2023 | 06:17 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
"What is a good, quality Spark Plug replacement for AC R44S ? Engine is stock - ‘70 W30 4-Speed." --------------> Anything NOT made of chineasium.
20 years ago I would have steered you to Autolites. BUT no longer made in the USA.
I did a little homework 2 years ago. In conclusion, I agree with 66 SC on the V-Power NGK XR5 3332.
Old Aug 30, 2023 | 06:34 PM
OLE442's Avatar
My '72 442 with 455 (Non W-30) had Champion RJ-12Y plugs in the 455 when I bought it off my brother. My brother was the second owner and I believe the Champions were in the motor from the first owner when he drag raced it back in the 1970's & early 80's. When I got the car I replaced the Champions with AC/Delco that were listed for the motor and, to me, it didn't seem to run as well. Eventually and few years ago, I found one of the original Champion RJ-12Y plugs and bought a new NOS set off Ebay and installed it the 455 and it seems to run noticeably better just like it did when I bought it from my brother. I bought another full set off Ebay as a back up set. The Champions did seem to make a difference to me.
My car has the original motor and had carb work and appears to have had a high performance cam at one time(holes drilled in the butterfly's to help it idle). I have never done a compression check but wouldn't be surprised if it didn't have internal work done to it back in the day. I looked up that plug and it's listed for w-30's I believe?
OLE442
Jamesbo
Aug 15, 2022 01:43 PM
Noel Anderson
Feb 27, 2021 03:54 PM
chasman414
Oct 30, 2014 03:15 PM
brandon 455
Jul 8, 2013 07:08 PM
72442clone
Jul 15, 2011 11:53 AM
