Spark plug verification
Old September 8th, 2019 | 07:27 PM
Macadoo's Avatar
I'd like to make the switch from AC Delco R45S plugs to NGK. I had no idea how hard it would be to cross reference heat ranges, at least with the Delcos. I'd like to go one small step cooler than the R45S plugs. I'm looking at the NGK XR5/3332 and I've seen that some folks here on CO are using the same plug. The plug NGK recommends for my motor ('76) is a #4 heat range; and since 12 is their coolest, 4 seems pretty hot. Here are my specs:
455 .030 over
9.7 CR
Iron heads
HEI with Proform tune up kit
Taylor 350 ohm per foot plug wires, custom fit
Cam w/ .512 lift, 227/233 @ .050
Run 93 octane
Old September 9th, 2019 | 05:49 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The factory plugs for a 76 in AC Delco is a 46, so your 45 is probably close to the XR5. You could try the AC Delco in a 43, that is what part selector says is a replacement for a 1970 Oldsmobile. You could try for NGK a 5670-6 or 5670-7 racing spark plug. This BR6S is the resistor style and cheaper.
https://www.summitracing.com/parts/ngk-3522/
https://www.summitracing.com/parts/ngk-2746/
https://www.summitracing.com/parts/ngk-2891/
Old September 9th, 2019 | 06:00 AM
Macadoo's Avatar
Thanks 307, I hadn't thought of looking up the stock AC plug for a '76 (although didn't I when I built this motor? I must have IBS, aging brain syndrome). I guess my question should be; what would be the proper heat range for my build? Since my '76 doesn't resemble a '76 motor other than the block, rods, and crank.
I want to get that AFR gauge and get it installed but thought an ignition makeover should come first.
Old September 9th, 2019 | 01:00 PM
Macadoo's Avatar
The NGK R5670 looks pretty good. Many street/strip folks seem to be using them. But I still wonder if they're too cool. I'm running out if time this season for warm weather tuning. Is it common for an engine to love cool weather, say upper 50s to lower 60s? Or is that telling me something? I realize the outside air is more dense but what else?
Old September 9th, 2019 | 01:55 PM
Yes, the engine should run better with cooler ambient temps. Just make sure the choke is adjusted so it works correctly in the cooler weather.
Old September 9th, 2019 | 02:27 PM
Macadoo's Avatar
Oh yeah, me and chokes are BFFs. Sigh, not really, but I got it good enough (it just opens a little too quickly).
So your answer begs the question, why? Is it just the denser/cooler air, hence the desire for an OAI hood (a working OAI hood)?
Old September 9th, 2019 | 05:03 PM
cutlassefi's Avatar
NGK XR5 gapped at .035.
Thry ran hotter plugs in ‘76 cuz they were lower compression and didn’t want to risk fouling causing a subsequent misfire as that would wreck the cats.
Old September 9th, 2019 | 05:18 PM
Macadoo's Avatar
.035 with HEI? Not .045?
Old September 9th, 2019 | 09:03 PM
cutlassefi's Avatar
Originally Posted by macadoo
.035 with hei? Not .045?
.035.
Old September 10th, 2019 | 12:13 PM
Macadoo's Avatar
.035.
You da boss
Old September 10th, 2019 | 01:26 PM
Yes, denser/cooler air.
Old September 10th, 2019 | 03:30 PM
Macadoo's Avatar
So, you're saying I should vent my AC into the carb!
Old September 10th, 2019 | 07:33 PM
Sure, why not. I heard there's some Mustang variant with a supercharger that uses the AC for the intercooler.
Old September 11th, 2019 | 10:29 AM
Macadoo's Avatar
You know, after I wrote that joke, I started wondering if it wouldn't be a good idea. But it would be a little like adding more fuel to a rocket to propel the [more] fuel, wouldn't it.
Old September 11th, 2019 | 07:45 PM
mrw8i's Avatar
Lookup Roadkill Boost Caboose
Old September 12th, 2019 | 01:50 PM
Macadoo's Avatar
Hey, I love Freiburger and Finnigan! I'll look it up.
February 19th, 2019 08:47 PM
HWYSTR455
July 13th, 2014 09:46 AM
brandon 455
July 8th, 2013 07:08 PM
tru-blue 442
February 27th, 2012 04:09 PM
85ttop442
April 27th, 2010 07:20 PM
Quick Reply: Spark plug verification
