Spark plug verification
Old Sep 8, 2019 | 07:27 PM
Macadoo's Avatar
I'd like to make the switch from AC Delco R45S plugs to NGK. I had no idea how hard it would be to cross reference heat ranges, at least with the Delcos. I'd like to go one small step cooler than the R45S plugs. I'm looking at the NGK XR5/3332 and I've seen that some folks here on CO are using the same plug. The plug NGK recommends for my motor ('76) is a #4 heat range; and since 12 is their coolest, 4 seems pretty hot. Here are my specs:
455 .030 over
9.7 CR
Iron heads
HEI with Proform tune up kit
Taylor 350 ohm per foot plug wires, custom fit
Cam w/ .512 lift, 227/233 @ .050
Run 93 octane
Old Sep 9, 2019 | 05:49 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The factory plugs for a 76 in AC Delco is a 46, so your 45 is probably close to the XR5. You could try the AC Delco in a 43, that is what part selector says is a replacement for a 1970 Oldsmobile. You could try for NGK a 5670-6 or 5670-7 racing spark plug. This BR6S is the resistor style and cheaper.
https://www.summitracing.com/parts/ngk-3522/
https://www.summitracing.com/parts/ngk-2746/
https://www.summitracing.com/parts/ngk-2891/
Old Sep 9, 2019 | 06:00 AM
Macadoo's Avatar
Thanks 307, I hadn't thought of looking up the stock AC plug for a '76 (although didn't I when I built this motor? I must have IBS, aging brain syndrome). I guess my question should be; what would be the proper heat range for my build? Since my '76 doesn't resemble a '76 motor other than the block, rods, and crank.
I want to get that AFR gauge and get it installed but thought an ignition makeover should come first.
Old Sep 9, 2019 | 01:00 PM
Macadoo's Avatar
The NGK R5670 looks pretty good. Many street/strip folks seem to be using them. But I still wonder if they're too cool. I'm running out if time this season for warm weather tuning. Is it common for an engine to love cool weather, say upper 50s to lower 60s? Or is that telling me something? I realize the outside air is more dense but what else?
Old Sep 9, 2019 | 01:55 PM
Yes, the engine should run better with cooler ambient temps. Just make sure the choke is adjusted so it works correctly in the cooler weather.
Old Sep 9, 2019 | 02:27 PM
Macadoo's Avatar
Oh yeah, me and chokes are BFFs. Sigh, not really, but I got it good enough (it just opens a little too quickly).
So your answer begs the question, why? Is it just the denser/cooler air, hence the desire for an OAI hood (a working OAI hood)?
Old Sep 9, 2019 | 05:03 PM
cutlassefi's Avatar
NGK XR5 gapped at .035.
Thry ran hotter plugs in ‘76 cuz they were lower compression and didn’t want to risk fouling causing a subsequent misfire as that would wreck the cats.
Old Sep 9, 2019 | 05:18 PM
Macadoo's Avatar
.035 with HEI? Not .045?
Old Sep 9, 2019 | 09:03 PM
cutlassefi's Avatar
Originally Posted by macadoo
.035 with hei? Not .045?
.035.
Old Sep 10, 2019 | 12:13 PM
Macadoo's Avatar
.035.
You da boss
Old Sep 10, 2019 | 01:26 PM
Yes, denser/cooler air.
Old Sep 10, 2019 | 03:30 PM
Macadoo's Avatar
So, you're saying I should vent my AC into the carb!
Old Sep 10, 2019 | 07:33 PM
Sure, why not. I heard there's some Mustang variant with a supercharger that uses the AC for the intercooler.
Old Sep 11, 2019 | 10:29 AM
Macadoo's Avatar
You know, after I wrote that joke, I started wondering if it wouldn't be a good idea. But it would be a little like adding more fuel to a rocket to propel the [more] fuel, wouldn't it.
Old Sep 11, 2019 | 07:45 PM
mrw8i's Avatar
Lookup Roadkill Boost Caboose
Old Sep 12, 2019 | 01:50 PM
Macadoo's Avatar
Hey, I love Freiburger and Finnigan! I'll look it up.
Feb 19, 2019 08:47 PM
HWYSTR455
Jul 13, 2014 09:46 AM
brandon 455
Jul 8, 2013 07:08 PM
tru-blue 442
Feb 27, 2012 04:09 PM
85ttop442
Apr 27, 2010 07:20 PM
