Single to Duals 394 Same DS manifold?
Old Jan 11, 2009 | 11:37 PM
NAS Backyard's Avatar
The single exhaust crossover pipe in my 61 Olds is toast. I was thinking duals. Will I need a different manifold for the driverside? Mine currently dumps in the front. I can't remember what my 61 Starfire had on it . Thanks
Old Jan 12, 2009 | 04:30 AM
I don't believe you can run dual exhaust on the early 60s 394 without a dual exhaust manifold for the driver's side. This manifold dumps to the rear where as the normal manifolds dump down (using the crossover to the passenger side). The problem is that the pitman arm is behind the center link and the steering gear box gets in the way of running true dual exhaust. I have heard of people putting dual exhaust on one of these cars without a dual exhaust manifold but I have never seen it done. I don't think there is enough room to get the exhaust pipe to the rear of the car without hitting the steering gear box or getting in the way of the center link.
Old Jan 12, 2009 | 05:15 AM
Oldskeeper's Avatar
NAS head back to the yard where you picked up your car and there are a couple of 64 starfires that should have the LH exhaust manifold,there is also a 63 98. If it is a custom sport coupe it should have duals. I have heard that they will fit early 394's and clear the steering box.
Old Jan 12, 2009 | 11:59 AM
Thanks, thats what i thought. He should have one already off somewhere. I have a big list and will be heading up there soon. Theres no way I would even try to mount anything off the one thats on there.
Old Jan 12, 2009 | 01:13 PM
Toro68
Guest
Posts: n/a
My friend, Skip W, had daul cabs , on his black (with maroon insides) 1963 Starfire convertibe.
Old Jan 13, 2009 | 07:02 PM
Run to Rund's Avatar
61-2 used the same manifolds whether single or dual exhaust. The LH pipe snaked around everything and was only 2" OD iirc. The front of the right manifold had a cover plate instead of the crossover pipe. In 63-4, the dual exhaust manifold was different.
BCFKody
Oct 17, 2012 07:43 PM
TOONLOVESCHERYL
Apr 7, 2011 10:38 AM
davepnola
Oct 13, 2010 08:48 PM
hooddm
Ninety-Eight
Dec 30, 2009 05:46 AM
D88
22
Apr 18, 2009 09:36 PM
