Should I replace Timing chain? newbie...
Old Feb 5, 2010 | 05:29 PM
mr mojo's Avatar
Question Should I replace Timing chain? newbie...
Just bought a 70 delta 88 custom 455 a week ago. She's got just under 68,000 miles and drives great. Just had a tune up and timing is dead on. Everything seems ok but I am still worried about the timing chain... pretty sure its the original stock chain. I am going to have the engine totally rebuilt in the next year(I hope). If the chain broke would it ruin the engine? Does this car have the plastic coated timing gears? What was the recommended timing chain replacement interval? Can i drive for another 10,000 miles without to much worry? Thanks in advance!
Old Feb 5, 2010 | 06:47 PM
My rule of thumb is 80,000 miles for an OEM timing chain with the plastic-tooth cam gear. It's the cam gear that goes first. The two Olds motors I've had that threw their chains were both over 100,000 miles when it happened.
Old Feb 5, 2010 | 06:55 PM
ozoneblue's Avatar
Like i have always told my kids You dont know the history on the engine & just call it cheap insurance (wish i would have listen to my self many times} & it will tell some history
Old Feb 5, 2010 | 09:59 PM
It won't ruin the engine, you'll just coast to the side of the road after you lose power.
Old Feb 5, 2010 | 10:07 PM
Red Delta's Avatar
Registered Abuser
When I pulled the front cover off of my engine, the first time, I was horrified to see that there was a plastic gear for the cam. Seems like that design was built for failure.
Old Feb 5, 2010 | 11:56 PM
svnt442's Avatar
It was done to keep the engine quiet. Personally I never really understood that line of thinking, especially on the more hi-perf engines.
Old Feb 6, 2010 | 05:49 AM
70 cutlass s's Avatar
It's your engine, but if it was me and I planed on rebuilding within the next year. I would leave it alone till then. It doesn't sound like a worn out engine just old.
Old Feb 6, 2010 | 05:54 AM
citcapp's Avatar
With only 68,000 miles I would not worry about another 10k as long as your going to rebuild anyway. If you decide to wait longer to rebuild then I would replace the chain and gears. Just don't keep putting it of with the "I do it later" thing. Thats when a guy gets in trouble.
Old Feb 6, 2010 | 06:41 AM
mr mojo's Avatar
thanks to everyone that responded. I really appreciate it. I feel a little better now. I have heard so many horror stories about newer cars and timing belts, but not too much about timing chains and these dreaded plastic coated gears. Its an amazing engine and with the tune up, new air and fuel filters and trans service and the removal of the A/C compressor the engine has already gained a lot of power. I know that there is a lot more potential in there. Thanks again.
oldsguybry
Brakes/Hydraulic Systems
90
Nov 2, 2015 10:22 AM
bittersweet71
Mar 16, 2011 10:29 AM
442scotty
May 13, 2009 05:42 PM
ala74olds
May 6, 2008 07:38 AM
