Short poly locks?
Old Aug 25, 2013 | 07:30 PM
Erinyes's Avatar
Short poly locks?
I picked up Comp Cams 17043 roller rockers, and of course the poly locks hit the baffle. Cutlassefi has posted numerous times that the shorter poly lock will clear stock size valve covers, but which ones are they? The locks that came with the rockers are 1 1/8 inch tall. Summit lists a 4601 poly lock, supposedly 1 inch tall, and these are the shortest I can find.
Are they actually one inch, and not 1 1/8 inch? Or is there a completely different poly lock that is even shorter that I haven't found yet, that will work with the 17043 rockers?
Thanks.
Old Aug 25, 2013 | 07:49 PM
coppercutlass's Avatar
Chevy budget Olds powered
You can buy bare steal valve covers that look like o.e. covers that are 3/8 taller. I bought the chrome version for 35 bucks I wanna say. Some guys have also said they stacked 2 valve cover gakets up. They also sell valve cover spacers .
Old Aug 25, 2013 | 08:55 PM
Erinyes's Avatar
Problem is the PS bracket. Raise the covers very much at all, I'll have to jigger the bracket somehow. If they exist, I'd rather just find short enough locks to fit.
Old Aug 26, 2013 | 04:55 AM
cutlassefi's Avatar
Yes they will be 1". That along with double gaskets should get you where you need to be without bracket interference.
Old Aug 26, 2013 | 06:55 AM
Erinyes's Avatar
Thanks. When I couldn't find a lock 1 1/8" tall from Comp, I had to wonder if the 4601 wasn't the same lock that shipped with the rockers, and they just listed it as 1" instead of 1 1/8".
RandyS
Jun 20, 2014 01:30 PM
onofre442
Sep 10, 2013 02:24 AM
stlbluesbrother
Sep 9, 2012 08:18 PM
RAMBOW
Mar 16, 2011 03:56 PM
steve walker
Suspension & Handling
Nov 17, 2009 05:34 AM
