Running an engine vacuum pump
Yes for CC evacuation, Hopefully will add some power. The eng. was built for evac, (Low tension rings). What I'm wondering is if someone builds a kit with the mandrel and brackets I'll need to fit it to the engine.
Smitty at M&J Proformance runs the system youre talking about. He can tell you all about it. He is "Smitty275" on ROP . not sure if hes on here or not. But you can get his phone number off his website. google it
This is another one of those race engine mods that must be used as part of a total engine package. Simply bolting a vacuum pump/pan evac system onto an otherwise stock engine will not only NOT produce a measurable performance increase, it will likely DECREASE performance by the HP it takes to run the evac system.
Carl, uk
March 13th, 2014 05:43 AM
Kidcutty
July 13th, 2010 05:06 PM
