Rough Running 68 400
Old Aug 20, 2008 | 11:25 AM
68 Cutlass S's Avatar
I recently rebuilt my 68 Olds w/400. I replace the distributor ignition with an HEI, the stock intake with and Edelbrock performer 455 and the Q-jet with an Edelbrock 600 carb. I'm experiencing a surge in the engine at low RPM's. It almost feels like a miss, but goes away at higher RPM's. I've put new plug wires,plugs,fuel pump and filter, and even run a wire direct from the battery to the Distributor ( I thought maybe low voltage somehow). The HEI distrubotor is new, but it is an in-expensive aftermarket one. Could an ignition module cause the surge, or do they just fail altogether. Any suggestions will be greatly appreciated.
Old Aug 20, 2008 | 01:17 PM
You can generally remove the HEI module and have them checked at your local auto parts store. They aren't very expensive if they are bad.
Old Aug 20, 2008 | 01:48 PM
88 coupe's Avatar
Junior Member
Originally Posted by 68 Cutlass S
........ experiencing a surge in the engine at low RPM. It almost feels like a miss ,.......
"Surge" and "miss" are two different symptoms, with two different causes. You'll need to clarify.
........ but goes away at higher RPM ........
Define "lower" and "higher" RPM.
........ Could an ignition module cause the surge ........
Whether it's a "surge" or a "miss" it's highly unlikely.
Norm
Napoleon1991
Apr 17, 2015 09:39 PM
Double D Farms
Jul 30, 2014 06:40 AM
66ninetyeightls
Apr 19, 2010 09:30 AM
silverriff
Mar 21, 2010 10:12 AM
tex70
Jun 20, 2007 05:07 AM
