Rod weep holes
Old Sep 4, 2023 | 08:47 AM
bw1339's Avatar
Rod weep holes
Hello. I'm refreshing a '68 455. The rods have weep holes (term?) and the old rod bearings are slotted on the side of the holes. My new bearings are not slotted.
Is this feature worth kepping? Thanks.
Old Sep 4, 2023 | 12:10 PM
BillK's Avatar
Olds did away with the slots in the rods after a while so I don't think they were as needed as some might think. I wouldn't worry about it much. I suppose if you wanted you could take a Dremel tool and make the cutouts in the bearings
Old Sep 4, 2023 | 12:56 PM
edzolz's Avatar
The spurt holes were originally supposed to be oriented so the oil from the spurt would spray in the opposite cylinder bore and also lube the camshaft lobes. Don't know why that was discontinued.
Al2011
Sep 25, 2013 05:07 PM
805cut
Jun 11, 2012 05:06 AM
craftsman1956
Suspension & Handling
Jul 16, 2010 09:56 PM
Applekrate
Dec 2, 2009 05:57 AM
