Rocker Arm Torque Check
Old Mar 24, 2016 | 06:32 PM
jeffsims's Avatar
Trying to make sure I understand torque procedure on 400ci rocker arms..
When in installing the arm assy and bolts to each cylinder, the valves should be in the full close position and then torque evenly to 25 ft-lbs.
My rockers are already installed and I am just rechecking the torque after first drive. Can I check and re-torque (if needed) with the valves in any valve position?
Thanks,
Jeff
Old Mar 24, 2016 | 07:17 PM
Yes, as they are already tightened down. This is not a requirement but will not hurt to give you peace of mind.
CutlassLegend
Sep 21, 2011 02:56 PM
ddx77
Aug 6, 2011 04:10 PM
70cutty
Aug 15, 2008 03:14 PM
gibbo69olds
Apr 24, 2008 12:29 PM
