Rocker arm noise
Old Aug 25, 2011 | 06:35 AM
antweave's Avatar
Rocker arm noise
I installed some edelbrock basic performance series chrome valve cover on my stock build 455 and while I was doing that I change the oil and put in some rotellia heavy duty 15w-40 oil since I live in north louisiana and it has been in the 100's since May. I figure the thicker oil would not break down as easy. But when I start the engine in the morning on a cold start I hear a slight bit of rocker arm noise. I'm not sure if they are not getting oil fast enough or they are hitting the valve covers or did the thicker stock covers kept the noise quiet. Heeeeeeeeeellllllp!!!!
Old Aug 25, 2011 | 07:19 AM
Rickman48's Avatar
Pull the covers one at a time and listen. If no noise, double the gaskets.
I use weatherstrip adhesive to the cover, on the two together, and axle grease on the heads, so they don't stick.
Old Aug 25, 2011 | 07:43 AM
X2- If thats all you've done then they are probably hitting the cover or baffle.
Old Aug 25, 2011 | 12:07 PM
antweave's Avatar
rocker arm noise
If the rocker arms are hitting the inside of the valve cover or the baffle will this cause any damage to my rocker arms over a extended period of time.
Old Aug 25, 2011 | 12:08 PM
Not something I would want happening!
Old Aug 25, 2011 | 01:30 PM
66ninetyeightls's Avatar
Land Yacht Captain
Its not going to be any good for it thats for sure. Most likely won't hurt the rocker but could take out the pushrods.
Old Aug 25, 2011 | 02:27 PM
ah64pilot's Avatar
FYI, Rotella is no longer a high zinc/phosphate oil. It now meets the criteria of other auto oils designed to be used with catalytic converters and the diesel particulate filters. I would consider using a high quality 20W-50 racing oil with a high zinc content if you are worried about oil pressure on a hot day.
CutlassLegend
Sep 21, 2011 02:56 PM
65cutty
Apr 10, 2009 04:29 PM
Gary Lagacy
Sep 20, 2008 01:35 AM
70cutty
Aug 15, 2008 03:14 PM
gibbo69olds
Apr 24, 2008 12:29 PM
