Rochester QJet rebuild kit
Old Mar 17, 2023 | 03:16 PM
jpilk99's Avatar
I have a '72 Olds 98 with a 455 and Rochester Quadrajet that I'd like to get a rebuild kit for. I assume, like most all other carbs, I need to find the precise kit for my carb. I can see, vertically, to the right of where it says "Rochester Quadraject" on the drivers' side, the numbers: 70412251 RE and then a 1312 below.
Can anyone tell me how to look up this exact carb for a rebuild kit?
Thank you!!!!
Old Mar 17, 2023 | 03:25 PM
therobski's Avatar
check Mike out I have used them several times. https://www.carburetor-parts.com/ They can help you.
Old Mar 17, 2023 | 03:38 PM
rocketraider's Avatar
Oldsdruid
Give the parts store the number you found and get the kit, new float and fuel filter.
Any more carb kits cover multiple applications, but the parts in the kit are generic to all of them. Kit will include new gaskets, pump, needle and seat, check ***** and linkage clips. Float is sold separately.
Do a good teardown, cleaning and inspection, then reassemble using the 1972 factory Chassis Service Manual. You may have to tweak the new float arm to set float level correctly.
Old Mar 17, 2023 | 04:30 PM
70412251 is the carb number. I still use Hygrade kits for most of my rebuilds. I also suggest replacing the plastic float as a preventative measure.
Old Mar 17, 2023 | 04:58 PM
Sugar Bear's Avatar
Compare the old gaskets to the new, they must have the same holes. Lay one on top of the other and compare both sides old-to-new, once the correct gaskets are identified remove the other gaskets supplied in the kit from the work/assembly area. I learned this the hard way.
Good luck!!!
Old Mar 17, 2023 | 06:18 PM
I worked at auto parts stores through the 80s and 90s, and as rocketraider said the kits are universal and cover multiple applications.
The Hygrade kit Joe mentioned is very good and is what I have used over the years. NAPA has been my go-to for carb kits for decades.
I use spray can carb cleaner to blast through the passages to ensure there’s no blockages.
Old Mar 17, 2023 | 09:07 PM
Oldsdruid
I'm a true dinosaur. I still have a 5 gallon bucket of carb and parts cleaner, and several metal parts baskets. The good stinky stuff that has gotten hard to find and that you have to remember to not put plastic parts in!
Then a triple water rinse and about 50psi of compressed air to blow out all the passages. Wearing safety glasses of course.
Old Mar 18, 2023 | 03:26 AM
ourkid2000's Avatar
I don't think you could go wrong with the rebuild kits from Cliff Ruggles (he wrote a pretty good book on the QJet as well):
https://cliffshighperformance.com/pr...t-rebuild-kits
The accelerator pump seems to be the weak spot in the cheaper kits and I know the ones Cliff sells are really good quality.
Old Mar 18, 2023 | 07:29 PM
BillK's Avatar
SInce the owner of Quadrajetparts.com passed away about a year ago I have bought three kits from these guys:
https://quadrajetpower.com/
Very complete kits and they have the updated accelerator pumps that will survive the Ethanol in the fuel. I have been very happy with them. You can look up your carb number on their site.
I would stay away from parts store kits. Most of them have been sitting on the shelf for years and the gaskets are dried up and they will not have the newer pump material.
Old Mar 19, 2023 | 06:57 AM
jpilk99's Avatar
Thank you, and others, for options on which kits to buy. My biggest question was knowing how to get the RIGHT kit that fits or matches mine. I trust there are many different Rochester designs, sizes etc so I’m not sure how to find a kit that Matches mine.
Old Mar 19, 2023 | 07:16 AM
As previously stated (Post #3 - rocketraider) kits will include various parts/pieces. Use the ones specific to your carburetor. Even when you purchase a kit specific to a select carb. # there will be some parts in the kit which fit select variants of that specific carb. It's pretty easy really - match the parts you need.
Old Mar 19, 2023 | 07:34 AM
jpilk99's Avatar
Ahhhhh. Now I get it. Thank you
Old Mar 19, 2023 | 07:35 AM
I've found having a flat surface to work on makes for an easier rebuild, etc. when working on a carburetor.. Grab a piece of 2"x4", cut & secure into four pieces, drill a couple holes for the mounting bolts of the carburetor, fasten down the bolts and you have a great mounting stand to work on. The interior base of the carburetor nestles into the center of the 2"x4" void. Nice platform to work from quick/easy to build.
Old Mar 19, 2023 | 07:41 AM
I guess this depends on if you are a woodworker or a metal worker. I've found it easier to just use hardware store bolts and nuts. I have to be honest, I rarely have the carb apart long enough to even take the time to put these in.
Old Mar 19, 2023 | 07:45 AM
I think we agree a stable platform lends itself to a more suitable work environment.
Old Mar 19, 2023 | 07:49 AM
BackInTheGame's Avatar
Using the resources noted in posts 3, 4, 6, 8, and others - CONTACT the seller and tell them which carb you have (post #4) and any of the reputable sources listed will get you what you need.
Old Mar 19, 2023 | 08:01 AM
Oldsdruid
Don't get hung up on that. A Ninety Eight 455's kit is no different from a Cutlass 350's.
Give the parts store the 704xxxx number you've found at the left rear corner of the float bowl. It's that simple. The kits include parts for multiple applications as a matter of consolidation and economics. The big thing is the kits include multiple air horn, venturi cluster and throttle plate gaskets. Rebuilder is expected to match the correct new gasket to the carburetor and toss the unused ones.
Here's the 1974 FACTORY parts book info on this repair kit, which Oldsmobile calls an "OFF-KAR" kit.
Group 3.725 p/n 7039258, 71-74 4BC.
This means the FACTORY sourced Rochester kit includes parts for ALL 1971-1974 QuadraJet four-barrel carbs, on both 350 and 455 engines.
That p/n is long obsolete and if you find one it will be decades old. In that time the gaskets and pump diaphram will have dried out/curled up and won't be worth the effort to install. Been there.
If you're still unsure about the advice we've given you, send the carburetor to Sparky's Carbs, QuadraJet Power or other reputable carb specialist. They'll tear it down, assess condition, clean it, reassemble it using ethanol-resistant components and set everything to factory specifications.
Old Mar 26, 2023 | 01:50 PM
jpilk99's Avatar
So, I am happy to report that I've been working with the guy at Quadrajetpower and bought a complete rebuild kit. He's actually been great getting back to me on questions. But I'm stuck on 2 things (at the moment) and hoping you good folks may know:
The kit included a Power Piston Retainer, a little white plastic bushing (see first pic attached) - I know where it goes on the Power Piston but no idea how to get it there. Can't slide it up from the bottom, nor down over top ...unless I'm supposed to pull out (somehow) the "T" at the top that supports the rods.
The kit also included 2 Choke Shaft Seals, the little black rubber seals (see second pic). . I put one of them inside the larger black plastic "disc" that the choke shaft arm goes through an into the carb itself. But I don't know where the other one goes
If anyone can shed light on these for me, I'd be grateful. Thanks all!!!!
Jay​​​​​​​
Old Mar 26, 2023 | 02:57 PM
The ring is spilt so it can be opened and put onto the shaft:
https://quadrajetpower.com/power-piston-retainer-new/
Old Mar 26, 2023 | 03:29 PM
jpilk99's Avatar
Thank you. That's what I thought - but didn't want to slice it only to find out I shouldn't have. :-)
Old Mar 26, 2023 | 04:14 PM
jpilk99's Avatar
All set on these, folks. Thank you. The guy at Quadra Jet Power has been incredibly helpful (emailing me multiple times). Can recommend him/them enough!!!
Jay
Old Mar 26, 2023 | 07:54 PM
Thanks for the info and recommendation. It’s helpful to get first-hand information about dealing with a company on the internet. Otherwise it’s just another web page. Good to know these folks are knowledgeable and response. 👍
Old Mar 27, 2023 | 06:27 AM
allyolds68's Avatar
I'll second Cliff's kits. I understand he's out of the rebuilding business himself but the kits he supplies are the best
dom992
Jul 26, 2014 05:42 PM
Bfg
May 10, 2013 05:21 PM
AirborneRME
Dec 3, 2012 04:33 PM
808olds
Oct 7, 2010 10:05 AM
The Stickman
Jul 7, 2009 03:43 PM
