Resurrecting a Totalled Toro
inherited a motorcycle trike project about 2 years ago. The person who gave it to me passed away before he could tell me what year or model of Oldsmobile he had used. All I know is that it was an Olds, front wheel drive V8. The engine, I was told is good, so it's worth pursuing. The only numbers I have been able to get from the motor/transmission are the following:
I believe it's a big block, I read that if the width between the valve covers is 14" it's a big block. It's just at 14"
Here are the #'s
409/147 On both sides
7A by #1 (i think #1, it's the front drivers side cylinder)
The transmission had a plate with the following numbers if this helps
Here are the #'s
If it's a big 7 and a smaller A, the heads are 72 350 heads.
If it's a big 7 and a big A they are Olds 307 heads.
The block casting number will be right by the oil fill tube on top/behind the water pump.
395558 2 would make it a 350.
