Is this a restamp?
Old Aug 25, 2011 | 10:19 AM
TK-65's Avatar
Is this a restamp?
The V and T are much bigger than the rest of the serial code. My two 65s are not like this at all. Mine are all the same size, much deeper and very sloppy. This is from a supposed 66 tri carb vert.
Old Aug 25, 2011 | 10:54 AM
Nilsson's Avatar
Hard to say, warranty blocks were stamped with the original block vin by the tech doing the work. That is why you see in some instances blank pads for the tech was to lazy or forgot to stamp. The original block was destroyed.
Don't know if that be the case here but an fyi anyway.
Old Aug 25, 2011 | 11:44 AM
CQR's Avatar
CQR
Here's the stamp on my 67 the letters are much bigger. I don't believe my motor has ever been out.
Old Aug 25, 2011 | 03:33 PM
jensenracing77's Avatar
i had heads from 67 442 that had bigger letters also.
Old Aug 26, 2011 | 06:09 AM
stan 65 cutlass's Avatar
sounds like you should suspect the other heads with small letters
Octania
Oct 15, 2024 04:10 PM
Ron McHugh
Feb 12, 2013 06:15 PM
leepear
Oct 27, 2010 06:02 AM
leepear
Oct 25, 2010 07:20 PM
toplessrocket
Mar 9, 2008 07:22 PM
