Removing Gallery plugs???
Old Dec 9, 2012 | 02:36 PM
chasman414's Avatar
I have a 455 toro block that I have had hot tanked, magnafluxed, and pressure tested.Everthing checks out great and the block looks new. I removed the front gallery plugs no sweat, but the rear plugs are stuck big time. I put a torch on the outer driverside rear plug and used an air impact wrench on it but it did not move and the allen type head started to strip. I didn't heat it too much because I was afraid I would hurt the block.The inner plug is some wierd square type head that I don't think I have a wrench for. I put kroil inside and out on both of them 2 days ago and left it. Any suggestions???
Old Dec 9, 2012 | 02:44 PM
Milan..'s Avatar
Those plugs need to be drilled out and removed with square tapered extractors. You will probably have to drill them to at least 3/8. You will need square sockets to drive them.
Seems like a big pain , but this will work. Also the oil galleries will need to be cleaned again. Thanks Milan
Old Dec 9, 2012 | 05:46 PM
chasman414's Avatar
oil gallery plugs
Where would I find these at?? I've never seen them before.
Old Dec 9, 2012 | 05:58 PM
Run to Rund's Avatar
I have found Mopar spray rust penetrant to work well. You can also whack on them with a hammer to help break them loose.
Old Dec 9, 2012 | 06:01 PM
You might benefit from reading this thread (most recent post about an hour and a half before you started this thread).
Old Dec 9, 2012 | 06:03 PM
2blu442's Avatar
Is the Allen head plug on the back, not down in a hole? You might try brazing something to it that you can get some torque on. Either a section of the allen wrench, or even a bolt.
Then for the other piece, here's a thread talking about the plug with a square hole in it.
https://classicoldsmobile.com/forums...ving-plug.html
Old Dec 9, 2012 | 06:04 PM
2blu442's Avatar
Eric... you must type just a little faster than I
Old Dec 9, 2012 | 07:37 PM
Bernhard's Avatar
Good post. I had to use this method yesterday to remove my plugs from a 73 455. I let the plug sit with penetrating oil and heated them fail. After stripping the head of the plug I tried to shock it free with a chisle notch and punch fail. I could have saved my self some time if I went straight to the easyout.I used the 3/8 easyout and it came out easy.Good luck removing your plugs.
Old Dec 10, 2012 | 06:15 AM
chasman414's Avatar
Thanks guys for all the help, wish me luck!!!!!!!!!!
Old Dec 10, 2012 | 10:11 AM
Milan..'s Avatar
Got my set at Sears , you will need square sockets too ......
bob p
Apr 10, 2015 01:55 PM
don71
Oct 14, 2007 07:25 PM
Patrick
Sep 19, 2007 05:28 AM
frdmftr
Sep 5, 2007 11:20 AM
Kennybill
Jul 19, 2007 03:22 PM
