Rebuilt 400
Old Apr 21, 2009 | 07:01 PM
todd66442's Avatar
Rebuilt 400
I went to turn over my 400 rebuild by hand and it will freely turn 180 degrees and then stops. I was wondering what the problem could be. What am I not seeing? What is stopping it from going 360 degrees (full turn) ? Any one?
I have the spark plugs out, the timing cover is on, fuel pump was in and then I took it out to see if that was the culprit but it still stops at 180. Please advise.
Thanks, Todd
Old Apr 21, 2009 | 07:15 PM
cts-v's Avatar
Does it have flat top pistons, decked block, machined heads or anything else that could affect Piston to valve clearance? I hope that's not it....
Old Apr 21, 2009 | 07:58 PM
Coltonis's Avatar
Obviously, its that mouse that ran into the intake manifold when you weren't looking
(lol, this was not a productive comment. I apologize.)
Old Apr 21, 2009 | 08:48 PM
dan2286's Avatar
It could be many things. You can start taking components off of the engine one by one and check the rotation after you take something off. Start with the easy stuff like oil pan(if its on), timing cover, dist.(if its on), oil pump. Then if none of those things free it up, take off the rockers one by one and see if it will rotate. I would think the next thing would be the cam and timing chain, if its not them remove the heads. Then move on to the pistons, checking the rotation after each one. The last thing would be to take off the main bearing caps one by one. Hopefully you dont need to take the whole engine apart, but this is the only way to find out whats stopping it if you cant see anything physically hitting.
To prevent that from happening again, it is a good idea to see if the engine rotates as you are installing components. That way if you find a problem, you wont have to take apart the whole engine to find it.
Old Apr 22, 2009 | 06:00 PM
todd66442's Avatar
Thanks all, I did not build it so I went to the machine shop and asked them, they were no help. If I don't find it doing the first few procedures you mentioned above, I'm taking it back to them. They did a 65 400 for me a few years back and all was good ,so I don't know whats going on here.
Thanks, Todd
Old Apr 22, 2009 | 06:03 PM
todd66442's Avatar
No, as I told him to build to original specs. Except for the usual hardened seats...etc.
Thanks, T
brandon reynolds
Apr 10, 2012 12:06 PM
brandon reynolds
Mar 5, 2012 03:51 AM
Octania
Feb 12, 2012 12:26 PM
tysons
Nov 2, 2011 08:17 AM
Nailhead 88
Jul 29, 2008 11:42 AM
