Pushrod Question
Old Jan 22, 2011 | 07:53 AM
dre's Avatar
dre
Pushrod Question
Can anyone tell me the benefits or disadvantages of having thin walls where the pushrods are supposed to go through? I'm looking at a set of C heads that I may purchase off of craigslist but they have been opend up and the walls for the pushrods are thin i'm told and come with sleeves.
Can someone elaborate?
Old Jan 22, 2011 | 09:13 AM
I'm guessing that the prior owner was using larger diameter (and thus stiffer) pushrods?
Old Jan 22, 2011 | 09:47 AM
Chesrown 67 OAI's Avatar
also its been know to enlarge those holes after a HUGE amount has been milled off!
Better ask more questions -- and especially get the seller to verify that there are no cracks in them -- or promise a full refund including return shipping if you test them and find cracks!! i learned that lesson the hard way with a set of "C" heads I bought off of a seller right here on CLASSIC OLDS - not even Craigslist!!
Old Jan 22, 2011 | 09:59 AM
72 cutlass455's Avatar
When using stronger valve springs and higher lift cams a thicker larger diameter rod is cheap insurance. Bending rods loose power and can fail.
RAMBOW
Brakes/Hydraulic Systems
Feb 2, 2015 05:07 PM
tomngary
Sep 20, 2013 06:24 AM
Warhead
May 31, 2011 01:24 PM
jc83
Mar 22, 2010 04:33 PM
54olds
Mar 31, 2008 06:07 PM
