Powermaster 9610 or factory starter ?
I recently purchased a parts car with a ton of parts- came with a nearly new 9610 mini starter.
Am I better off using the factory starter or should I give this thing a try? My motor is pretty much bone stock, non header, automatic.
Not sure if the 9610 might throw some installation head aches at me. My factory starter is almost new so the only advantage I'm seeing is weight…not a big deal to me.
Thanks for any suggestions/ideas.
I put the same starter on my 76 cutlass supreme . Mainly stock with a few bolt-ons. I needed a new starter and decided to spend a little more to drop a few pounds. If you don't mind a louder cranking starter than I would install it and get the weight savings from your stock starter. No installation headaches at all.
I hope this helps
Cheers
Eric
I hope this helps
Cheers
Eric
headers will not fit between standar starters? i see mine is very big but i will find out when engine will comes on enginestand and can try header and starter. i see they have some small heavyduty types ones on ebay.
I put that same mini stater on the car I'm building and I am very happy with it. It's way lighter than the stock starter so installing it is easier. I've dropped a stock starter on my face once and that was no fun. The power master will take a little wiring change but not to hard.
6884OldsRockets
September 24th, 2015 10:49 AM
81 regency
March 1st, 2012 11:23 PM
