Power steering belt loose
Can someone please help, my power steering belt is loose and i cant figure out how to tighten it up it any body has time please lend my a helping hand also if its not the belt i did buy a new power steering pump if you can walk me on how to change it I thank you in advance.
To remove the pump you are going to need a "pulley puller" as it's pressed on. I did mine myself but I don't know how mechanically inclined you are.
You can rent the tool at most auto stores.
This is a pulley puller....
Can anyone tell me a great brand of quiet belts? I'm having the same issue for my 71 Oldsmobile rocket 350 engine. I'm not sure what it came out of but I know for sure that's the engine, and the belt is constantly squealing. I have taken the advice of the comments here by tightening the power steering pump, (which I have noticed has a pretty new looking Gates belt that the previous owner must have put on) but I believe it is the alternator belt, however I'm having a hard time finding a part number for it. I want to get a Gates belt for the alternator belt as well, does anyone know a parts number?
Hello,
Does anyone have a picture of which lower bolt on from of PS pump and lower rear bolt on back of pump that need to be loosened to tighten pump belt? For a 1970 cutlass supreme w/AC. Do you have to loosen the alternator belt also to adjust PS belt? Also I found per the threads on here that there is supposed to be a hole in the PS pully on mine there are no holes, the Alternator belt is on the same pully as the PS pump belt.
Thank You,
Thank You,
Last edited by zmaster77; January 16th, 2022 at 09:31 AM. Reason: additional question
AJFink
October 16th, 2018 09:59 AM
