Power estimate?
Old Jan 25, 2021 | 06:08 PM
Jhucks03's Avatar
Power estimate?
Anybody want to throw numbers out there?
455
-‘68 Toro rotating assembly
-C heads serviced and cut .020”
-Flowtech 1-3/4” primary headers
-750HP double pumper
-Torker intake with adapter/spacer
-HEI
-Thumpr cam: 234 int./249 exh. | .500int. .486exh | 107LSA
TH350 10” Summit converter (2,800-3,200)
3.42 rear gears
71 Cutlass: 3,750# with me in it and 1/2 tank of fuel.
Old Jan 27, 2021 | 01:45 AM
DROLDS707172's Avatar
Power estimate
Stock heads no port work? 330hp and 460ftlbs torque, all done by 5000 rpm
Old Jan 27, 2021 | 05:34 AM
A friend had a 66 cutlass with a very similar engine build. He was using a performer manifold, with a 850 Edelbrock Q-Jet and a comp cams 292 grind. Same headers, car made right at 300 rwhp. With a th350 trans, 10 inch converter and 4:10 gears ran 12:50-12:40s pretty consistently.
Old Jan 27, 2021 | 06:07 AM
Jhucks03's Avatar
Sticky tires? If so, you remember what they may have been? Just out of curiosity.
I know it’s a far from optimized combo, but it’s the result of lots of parts scrounging and deal searching. I do plan to do something about the heads at some point in the future. But it’s a lot of fun to drive at the moment. I will visit the chassis Dyno when I get some decent exhaust on it, instead of the pieced together crap I have now.
Old Jan 28, 2021 | 06:36 AM
He usually ran a 28x11.5 Hoosier Quick Time Pro DOT tire. Sometimes he used Mickey Thompson, usually he would run whatever he could find that was cheap or used, or borrowed.
Old Jun 2, 2021 | 09:10 AM
Jhucks03's Avatar
If anybody is curious, an update.
Went to chassis Dyno today. Ran out of time so had to drive it instead of trailer.
Made 300hp/325tq at the wheels all done by 5100. WOT AFR was 11.8 with cutouts open.
Best 1/8 mile pass so far with me still learning has been 7.96@85.6mph with a 1.71 60’
Old Jun 2, 2021 | 11:36 AM
Rallye469's Avatar
That's pretty good! Solid 12.0 car.
-peter
Old Jun 5, 2021 | 06:42 PM
69CSHC's Avatar
455
-HEI
3.42 rear gears
Very nice setup, your engine started life very healthy to begin with, an actual (not rated) 350 gross flywheel HP.
Awesome numbers. Your track performance indicates you are leaving nothing on the table. 300 HP at the wheels with a 3750 LB test weight cant do much better as is....
You've done a helluva job. For comparison sake a 1970 LS6 Chevelle puts out 285 HP to the wheels and 320 LB FT factory correct and flawless.
Matt69olds hit the nail on the head regarding HP and is so thorough in his post that you can pretty much take the 1/4 mile ETs "to the bank" in relation to your cars performance. The 71s 1/8 mile calculates to a 12.60 in the 1/4. 12.40s makes sense when going from a 3.42 to a 4.10
Old Jun 5, 2021 | 10:28 PM
VORTECPRO's Avatar
Thanks for the track update. 7.96 X 1.57 = 12.49
Old Jun 27, 2021 | 06:10 PM
Jhucks03's Avatar
Another update. Went to some used skinnies upfront and junkyard Windstar e-fans.
Result:
7.85@86.5mph w/ 1.69 60’
Best run yet in hottest, most humid conditions yet.
Old Jun 27, 2021 | 06:24 PM
VORTECPRO's Avatar
Result:
Nice work!
Spartan676971
May 27, 2020 09:46 AM
DQ81
May 30, 2014 06:12 PM
cutlassefi
Aug 20, 2012 12:49 PM
FAZ442
May 19, 2012 11:28 AM
MY71CUTLASS
Feb 13, 2012 05:40 PM
