pls check my math....head volume
Trying to calc the amount I need to take off the heads (66 425)to make up for the 3cc approx. I have taken from the bowls .Dia. head chamber = 10.5 cm
depth of segment ( not part of chamber and to be excluded from cm sq. of circle.) = 1.6 cm
Area of circle = 81-67 sq cm
less area of segment(9.05 sq cm)
= 72.62 sq. cm
x .05 cm =3.6 cc
.05 cm = 0.13 inch ??
Anyone please
mike
cutlass efi , 80 cutlass ,
THANKYOU .
The prospective engine builder (now ex prospective engine builder ! )said "and we can take a slice off there ". It`s not a bloody cake so I am off to talk to another --more expensive but with a good reputation --where I should have been for a start.
THANKYOU .
I talked to my machinist about milling Oldsmobile heads. He recommended not going more than .0030 of an inch. He wacked another set .0055 upon the customers request and the head warped shortly after installation. He said their wasn't enough material to insure a true deck surface. He did not tell me what letter heads had the problem and I'm sure there is differences. The other thing to be careful of when milling the heads is the need to mill the intake to match. This seriously decreases the resale value of the intake. You should not have to worry about the intake with milling the heads only .0020.
sb
