Piston ring orientation
I'm getting started on putting my 455 together. Opened up the box of SealedPower file-to-fit rings and see that there are two sets of compression rings. Eight are marked with red and have a bezel on top. The other eight have a yellow mark with a bezel on bottom. However, the instruction sheet that came with them doesn't specify which set goes on top or bottom.
I'm assuming that the rings with the bezel on top go in the top groove and the rings with the bezel on bottom go in the second groove...correct? I know that's how most performance rings are set up, but I couldn't find any online documentation to verify that it's the case here.
