Pick me a cam for a 455
I just bought a fresh 455 short block a guy had done and needed to sell it. It has 18cc slightly dished forged pistons that should give a compression ratio around 9.5-1. Stock small valved E heads, Dual plane 71 W30 Intake manifold, factory exhaust 2.25 with a pair of Dyno Max super turbo's. I am looking for a low to mid range cam with a rumble out the back. I prefer an idle around 800 rpm. The gears are 3.42, 4 speed M20, non power brakes. Would a factory W30 cam be a good choice? It seems old school to me and I want off idle power. I don't want to over cam the engine.
Thanks for any help.
Cam selection
There are lots of cams out there for your application. However, in order to obtain a noticeable idle and have good low end, I would opt for a cam with modest duration but ground on a tight lobe sep, maybe a 108 or even a 106. That should give you what you're looking for.
