Pick me a cam for a 455
Old Jun 19, 2009 | 01:20 PM
MN71W30's Avatar
I just bought a fresh 455 short block a guy had done and needed to sell it. It has 18cc slightly dished forged pistons that should give a compression ratio around 9.5-1. Stock small valved E heads, Dual plane 71 W30 Intake manifold, factory exhaust 2.25 with a pair of Dyno Max super turbo's. I am looking for a low to mid range cam with a rumble out the back. I prefer an idle around 800 rpm. The gears are 3.42, 4 speed M20, non power brakes. Would a factory W30 cam be a good choice? It seems old school to me and I want off idle power. I don't want to over cam the engine.
Thanks for any help.
Old Jun 19, 2009 | 03:51 PM
AJCDFIN's Avatar
Hey; I believe there were several grinds used depending on if it was an OAI and tranny type. Old school is still good schooling.
Old Jun 19, 2009 | 07:45 PM
cutlassefi's Avatar
Cam selection
There are lots of cams out there for your application. However, in order to obtain a noticeable idle and have good low end, I would opt for a cam with modest duration but ground on a tight lobe sep, maybe a 108 or even a 106. That should give you what you're looking for.
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
outlawspeeder
May 8, 2013 09:21 AM
sethj78
Feb 28, 2012 10:45 AM
ChrisM
Sep 11, 2008 08:45 PM
