Performer with OAI air cleaner, Who has done it?
Old Apr 28, 2016 | 07:51 PM
Troys Toy 70's Avatar
Once Olds Always Olds
If I understand correctly, I am thinking E-Brock Performer is 1 1/2 inches taller than stock intake on a 455.
I have seen lots of discussion on having the performer and the OAI flapper assembly, and that it can be done with a drop base, but who has done it? pics specs?
Has anyone milled the carb base by say 3/4 -1 inch. ( I know it's crazy, you loose the some of the intake's benefit by making the air/fuel flow make a tighter turn into the ports. However, how much turbulence is created in the air cleaner assembly when not at WOT, and the flapper is not fully engaged?) In other words, would you give up 5 to 10 horses on high end rpms, vs giving up 5 to 10 horses at lower rpms because of drop base?
Also, how does the A/C brackets fit with a performer?
I know the 04b in a spread bore is more of a direct fit, but I haven't found one yet.
I know I am probably over thinking this, but I need to make a decision soon, and just trying to weigh my options.
Old Apr 29, 2016 | 05:09 AM
lemoldsnut's Avatar
I am tagging in on this as I would like to know too.
Old Apr 29, 2016 | 08:30 AM
David DeCan's Avatar
Me too
Inquiring minds want to know. I have a 70 Cutlass Convertible we are swapping in a 455. Would like to put OAI hood and air cleaner assembly on the car in not too distant future. Will the Edelbrock Performer 2151 work? Can it me made to work? Thank you.
Old Apr 29, 2016 | 10:13 AM
ELY442's Avatar
I hope this can help you guys...http://www.drdecal.com/product/1001-...m-air-adaptor/
Old Apr 29, 2016 | 10:56 AM
Originally Posted by ELY442
I appreciate the information, and this maybe the best option to accomendate an aftermarket intake, but really looking for an example or two of a fully functional, with the flapper, air cleaner assembly on top of an aftermarket intake on a bbo.
Old Apr 29, 2016 | 11:24 AM
My442's Avatar
Mill carb pad 1".
Remove the rubber gasket from the plastic OAI top.
This works, but is tight.
Or this:
http://www.supercarsunlimited.com/19...-Top-i317.aspx
Old Apr 29, 2016 | 02:37 PM
scrappie's Avatar
Can somebody tell me what WOT means?
Old Apr 29, 2016 | 02:39 PM
WOT -Wide Open Throttle.
Old Apr 29, 2016 | 02:43 PM
Originally Posted by My442
Mill carb pad 1".
Have you actually done this? Any pics?
Old Apr 29, 2016 | 02:58 PM
scrappie's Avatar
costpenn
Nov 16, 2015 12:21 PM
squirell
Apr 23, 2013 02:58 PM
69CutlassAlex
Dec 2, 2011 08:01 AM
WTony
Jul 3, 2010 11:12 AM
