PCV hose on "67 CS 442
Old December 1st, 2019 | 08:09 AM
Rocket Olds's Avatar
Question PCV hose on "67 CS 442
had previous help on the correct pcv grommet and got that replaced along with correct valve but notice now when running the hose is collapsed. do I have too flimsy a hose or is something else going on? the only reason I had to replace the pcv was I was just checking things and decided to pull the old one and saw sludge in bottom of it. This led to removing the cover to make sure I hadnt bought a car knee deep in sludge. Once off the cover was spotless and valve train area also, no sludge at all. so cleaning the area from grommet area down with B12 I saw some light sludge coming from under the tray that is welded into the cover that keeps oil from being sucked into PCV so I soaked cover and cleaned until all was good under the tray. So now I am checking for leaks after putting cover back on and see the hose collapses. if it did this before my cleaning I never noticed. all ideas will be appreciated. See pic
what is wrong with this hose and valve?
Old December 1st, 2019 | 08:26 AM
That hose looks way too flimsy, almost like shrink tubing. It should be a reinforced hose, similar to a fuel hose.
Old December 1st, 2019 | 08:48 AM
X2, you need to use vacuum tubing available at any hardware store.
Old December 1st, 2019 | 01:55 PM
i went back with what was there. I was hoping that was the answer. Thanks again this web site is the best.
Old December 1st, 2019 | 02:25 PM
Oldsmaniac's Avatar
There is a repro hose made for that with a 90 bend there so it doesn't kink...
Old December 2nd, 2019 | 07:08 AM
thanks for that update, I will check it out.
Old December 2nd, 2019 | 08:22 AM
Oldsmaniac's Avatar
Old December 2nd, 2019 | 10:17 AM
thanks for pic. I found that hose and ordered it. About the pic, I wish my engine color was correct for the 442 as yours is. Mine is Cutlass gold. So far everything else is correct about the engine so until I win the lottery or the engine fails I aint painting it. Thanks to all, Mike
NotDads442
December 20th, 2018 06:13 AM
droldsmorland
January 17th, 2018 06:09 PM
at3reg98
May 4th, 2012 09:22 PM
theoldsrocket
March 11th, 2011 11:45 AM
1983oldsmobiledelta
December 2nd, 2010 04:37 PM
