Particle shards under valve covers
Old Mar 17, 2009 | 07:38 AM
DAN76's Avatar
Englishman
took the valve covers off and found some broken up small pieces of plastic in there! Looks like something has exploded but can't work out what it could be!
any ideas?
Old Mar 17, 2009 | 09:35 AM
70oldsW30's Avatar
Maybe petrified and then shattered valve guide seals.
Old Mar 17, 2009 | 02:20 PM
That was also my first thought. They are the only plastic parts in the area. Fortunately, the seals can be changed without removing the heads from the engine.
Old Mar 17, 2009 | 04:11 PM
DAN76's Avatar
Englishman
Had a quick look on Jegs and yes the Stem Seals do look like they could be the reason for the particles. They are black and would probably form a cylindrical shape about the size of a skateboard bearing.
It seems like they may have been there for some time, however the remains suggest that it's just one that's exploded. Are there likely to be any catastrophic consequences having run the engine or is it a minor problem?
Old Mar 17, 2009 | 06:05 PM
The worst problem is that you may see excessive oil consumption and some oil smoke in the exhaust.
68442CONVERTCO
Aug 21, 2021 10:22 AM
RAMBOW
Mar 20, 2017 06:58 PM
Rickman48
Mar 23, 2013 01:06 PM
jpc647
Oct 12, 2012 03:11 PM
oldzy
May 30, 2011 06:06 AM
