Overhaulin a 400 engine for my 66 442
Hello, I own a 1966 442 with the 400 engine. I build my engine Twice and had bad Luck, the 2 times ruined my engine.
First time I loose all oil presure, and now seems like number 3 rod enlarged and I found the rod bearing mounted one above the other, so my crankshaft and rods are damaged and I need to replace them.
now I need to buy a compleete overhaul kit, pistons, rods, rings, crank, etc.
I had purcahsed my parts at Mondello (no longer gives my confidence) and in Olds Performance Products (has treated me well)
My question is were do you recomend my to Buy my new kit to rebuild my engine at reasonable price and good quality??? I want to rebuild a street/strip car
thanks for the help
thanks for the help
thanks for the help
thanks for the help
You'll obviously need to purchase mostly used parts. But my point is it sounds as if the machine work may be as much of the issue. Make sure you have everything checked by a reputable shop otherwise you'll be right back where you started from.
Aussie67Delta88Custom
29
Sep 20, 2008 06:13 AM
