Once again......
Old Nov 26, 2012 | 10:51 PM
815Cutlass1972's Avatar
" Hoo yah "
Once again......
So it looks like I will be going with a Olds 455 again. This will go into my 72 W29. This time around it will be 72 F block .30. I'm thinking of using Probe forged pistons (11.63). I will be using a N-Crank. Looking at Comp Cam's Magnum 305 H or XE 284H. I'm thinking a Holley 850,Air Gap RPM, Hooker Headers. I'm thinking I may give Bernard Modello's version of Pro Comp Alum heads a try.
I will have 2.5 inch Pypes muffler system. th 400, 3500 stall, and shift kit or would a built 2004-r be a better choice for cruising? I have crazy 4.88 gears inside a 12 bolt posi. Old School Lakewood Traction Bars. I would like thoughts and insight on this. What gear should I stepped down too? I want to be able to drive this thing during a Power Tour someday, up to Detroit for the Woodward Cruise, and step onto the strip every once in awhile. If I can obtain 475 plus horsepower out of this I will be happy. Does this combo sound on track for that? I wanted to go roller, but Comp Cam package is too much imo. Looking forward to hearing thoughts on this.
Thanks,
Kino
Old Nov 27, 2012 | 04:27 AM
cutlassefi's Avatar
Why so high on the compression? I'd shoot for around 10.5:1. you can do that with either the Icon or Wiseco pistons. I'd definitely opt for the aluminum heads as well, you'll make your hp number with little to no problem. Otherwise your combo sounds good.
A 3.42 gear is a nice compromise.
I offer custom hyd roller cams with lifters for $725.00 shipped to your door.
Let me know if you're interested.
Thanks and best of luck on your build.
Old Nov 27, 2012 | 08:22 AM
" Hoo yah "
Thanks for you input! I thought that compression level would get me closer to my goal, but if 10.5:1 can do it then I'm all game for that! BTW these V/W pop-ups are making me angry.
Kino
Old Jan 7, 2013 | 02:59 PM
" Hoo yah "
Got a few parts in today. I love when new parts come, because it takes my mind off this crappy Chicago style winter. Wiseco pistons and Eagle H-Beam rods. BTW GO FIGHTING IRISH!!!
Old Jan 7, 2013 | 05:20 PM
ziff396's Avatar
3.42's work great for me behind the t-400. Sure an extra gear would be nice but it's fine the way it is as I don't run highway to much. If I had a four or five speed trans, then I would want more gear. Kind of a wash.
Old Jan 7, 2013 | 07:00 PM
" Hoo yah "
I decided to stay with the th-400. I think it will be easier on my wallet at the end of the day. Maybe I will try the overdrive whenever I build a 65 Cutlass resto-mod.
Globeguy
Feb 8, 2014 07:34 AM
ATrain1
Non-Olds Engines
Jun 24, 2012 11:55 AM
texxas
May 6, 2012 09:07 PM
gearheads78
Jul 3, 2011 07:42 PM
jeffreyalman
May 15, 2009 10:48 AM
