Olffenhauser 360 intake 455
Old Jan 7, 2022 | 09:14 AM
1977 C-10's Avatar
Looking for feedback on how well these perform on a street engine/stock heads mild cam. I purchased this one for $100.00 years ago. May put it & some other left over pieces on a budget build. Thanks.
Old Jan 7, 2022 | 09:45 AM
redbaron442455's Avatar
Check out my post from a few months ago, I ended up just going with a performer manifold.
https://classicoldsmobile.com/forums...8/#post1369170
Old Jan 7, 2022 | 10:32 AM
1977 C-10's Avatar
My intake is more like a dual plane. Not a 4 hole. It has both carb bolt pattern & a 1" cut into the divider. I will have to pix it to be clearer.
Old Jan 7, 2022 | 10:42 AM
1977 C-10's Avatar
Snagged this off this site. Mine does not have any bungs at all. It is marked 576B.
Old Jan 7, 2022 | 12:45 PM
1977 C-10's Avatar
No casting date. Nothing for vacuum ports or bungs.
Old Jan 7, 2022 | 12:52 PM
These Offy 360s are the goofiest intakes ever conceived. If the concept is so great, why has no one copied it in the last half a century (and the patent expired decades ago). Dividing the intake into two single plane intakes, each feeding one bank, is stupid unless you are running a flat plane crank.
Old Jan 7, 2022 | 02:05 PM
1977 C-10's Avatar
K. Anyone put the intake(s) to a dyno & compare worst to best in the 455 Olds family? Real numbers in TQ &HP.
Old Jan 7, 2022 | 02:30 PM
You realize that the answer will be different for each engine build, right? The cam and heads that make best power with a Performer won't be the same combo as the ones that make best power with a Torker or a Victor.
Old Jan 7, 2022 | 02:36 PM
1977 C-10's Avatar
Really? A basic street build 455 and run the intakes. Measure the HP TQ of each intake. In this case dual planes only.
Old Jan 7, 2022 | 02:39 PM
Feel free to build a motor and rent some dyno time.
Old Jan 7, 2022 | 02:47 PM
1977 C-10's Avatar
Flee, I asked if some has, not if someone would wait on me.
Old Jan 7, 2022 | 03:13 PM
cutlassefi's Avatar
WOT would only be one testing parameter. My bet is part throttle on that would be horrible. There’s literally no runner length and proportionally a huge plenum area.
Like Joe said, if it was so good why is it still so unique?
Old Jan 7, 2022 | 03:26 PM
1977 C-10's Avatar
The real numbers by a dyno would be the definitive answer. .What makes what. For this intake and the others. Asking if this has been done before.
Old Jan 7, 2022 | 05:44 PM
Wow this thread went sideways.
I have known boat people that loved these on their 455 boat motors. Also knew a great mechanic kid younger than me. He had one on a stock 455. Pulled the motor from a car. Rebuilt the carb and used that intake. That car ran like a some bitch.
Hundred bucks well spent. One Hundred dollars? You can buy a window crank for that now. Maybe.
Old Jan 7, 2022 | 06:02 PM
1977 C-10's Avatar
Bingo. Wanna drive the modern boys nutty? Add a ancient W-30 grind to the build. Fresh stock 'E' heads. These are setting on the shelf.
Old Jan 7, 2022 | 08:01 PM
onthereel's Avatar
I got $275 for mine on eBay last year, so $100 is a good deal no matter what. Seems like the popular opinion is that it stinks. I went with a Performer.
Old Jan 7, 2022 | 08:45 PM
1977 C-10's Avatar
Yes, I scored a Eddy Performer used w/xtra parts/gaskets/hardware for just over $200 5 years back. It went on the present 455. Has a custom cut Clay Smith Hyd/Aluminum heads/hper pistons. Ordered roller tip rockers & they sent full rollers. Anyway the left over parts aren't selling, so its time to retro-in-de-ghetto build.
chopolds
Apr 20, 2021 05:18 PM
Sgtsmitty
Jul 12, 2016 05:45 AM
67Rocket
Aug 13, 2015 07:05 AM
Don Roberto
Jan 13, 2015 07:46 PM
MattP_15
Dec 14, 2014 05:56 AM
