Olds Super 88 - 394 - 4bbl fuel leaks
Old Jun 4, 2025 | 04:03 AM
Johny's Avatar
Hello,
I have some leaks from my carburator 4bbl Rochester do I've ordered gasket set from rock auto. I've driven the car a few kilometers since I bought it recently. It drives fine. From what I know the carburetor was rebuilt some time ago.
Did someone make a mistake installing gasket?
In my set from RA I found a proper gasket. Am I right?
Have a nice day
Greetings from Poland
Johny
Old Jun 4, 2025 | 04:32 AM
Johny, I'd say that the gasket you used in the 2nd picture is closer than the gasket in the 1st pic.
Old Jun 4, 2025 | 05:25 AM
Sugar Bear's Avatar
The first picture gasket is wrong, the second one looks correct. When working on carbs I never throw away the old gaskets until finding the matching one in the kit, the other non-matching gaskets are removed from the work bench.
Old Jun 4, 2025 | 05:31 AM
Johny's Avatar
On the second picture is new gasket from set - I want to install it.
In my opinion someone made a mistake using such a gasket like on first photo - because of air leaks.
Old Jun 4, 2025 | 06:56 AM
Supernice88's Avatar
Art S
Here's a pic of when I rebuilt mine. You don't give the carb # but it looks the same as mine. The old gasket looks correct. Another problem I ran into was the throttle plates were getting hung up on the gasket. Over the years the dies to stamp them are wearing out or changing. You can see that with your's where it left a ridge at the openings when the parts got pressed together against the gasket.
Old Jun 4, 2025 | 07:03 AM
Johny's Avatar
Using a gasket like the old one will in my opinion cause Edyta dirty air to enter the carburetor and air leaks.
I have no experience with Rochester carburetors, hence I am looking for answers.
Old Jun 4, 2025 | 07:29 AM
Art S
I'm sure Rochester made those gaskets that way for a reason. There were multiple gaskets that came in the kit to cover the different car manufactures and years of the cars. It probably won't run correctly if you use the wrong one, but you can go ahead and do what you think is best.
Old Jun 4, 2025 | 08:28 AM
Charlie Jones's Avatar
Phantom Phixer
Use the gasket that covers best.
Yes, someone used the wrong gasket,
mb13
Mar 15, 2024 05:52 PM
BeenThere
Oct 27, 2022 05:43 AM
KQQLCAT
Oct 18, 2019 06:00 AM
synoptic12
Jun 9, 2019 03:34 PM
caddy60
Jun 27, 2012 10:54 AM
