Old TRW pistons?
Old Oct 13, 2009 | 05:27 PM
jensenracing77's Avatar
Old TRW pistons?
i have a set of old TRW pistons that are .40 over for a 455. if i build an engine should i use them or get new ones. they were in an engine that only ran 3000 miles and they had the bore a little tight in one cylinder and hurt that piston. i have a new one from the same era (early 80s) that is the same piston. so i have 7 used and one new one. i figure that they would be fine but wonder if there is something i don't know. i will have them balanced when i build a new engine if that matters.
Old Oct 13, 2009 | 05:58 PM
BIGJERR's Avatar
I bleed Oldsmobile
Ive done worse piston swapping and had engines live for many many years............Jerr
Old Oct 14, 2009 | 12:44 PM
i guess my biggest question would be, are new pistons better than old pistons as far as technology goes. on some stuff older is better and other stuff newer is better.
Old Oct 14, 2009 | 06:29 PM
Oldsguy's Avatar
Past Administrator
Specify which pistons you are referring to. I am sure a few builders here would be able to comment.
Old Oct 15, 2009 | 02:17 AM
i don't have a part number. just know that they are TRW .40 over pistons from the early to mid 80s
Old Oct 15, 2009 | 04:58 AM
Oldsguy's Avatar
Past Administrator
Bummer, I was thinking that they had a number stamped on them someplace. Oh well...
Old Oct 15, 2009 | 05:17 PM
i looked again and it does have numbers stamped into the top. i thought it was just TRW 40 but it is L2323040. can anyone tell me anything about them.
Old Oct 15, 2009 | 05:24 PM
svnt442's Avatar
Cast .040 over 10.25:1 (advertised) pistons
j_link
Aug 18, 2011 03:13 PM
gearheads78
Oct 10, 2010 01:23 PM
Daverd
Aug 17, 2010 10:56 PM
