Oil Pan Leaks
You will probably have to take out the motor mount bolts and lift the engine in order to let the front of the pan come down enough to clear the crank. I know this is true of a 455 in a G body, Not sure on earlier vintage ones. As far as which gaskets to use I'm not sure but be absolutely sure you degrease the sealing surface. I would probably reccomend that you use silicone gasket maker at the gasket joints, ie. rubbers at each end where they meet the side gaskets. Make sure you dont have a main seal problem. Olds does make a 2-piece main seal that is easy to install with the crank still in. Good luck
