oil pan gasket sealer?
Old June 8th, 2017, 01:43 PM
tommieb's Avatar
Hi have a quick question. Should I use a gasket sealer on my oil pan gasket when time to reinstall oil pan gasket. If it matters on a 371 motor. Rubber ends and cork sides. Thank you
tommieb is offline
Old June 9th, 2017, 04:06 PM
442Harv's Avatar
I would use Permatex, on the cork.
442Harv is offline
Old June 9th, 2017, 05:08 PM
71 delta88guy's Avatar
PLEASE use ultra grey. Or similar. Several companies make similar or just buy permatex ultra grey. NEVER use permatex regular blue. Designed to break off and clog oil pump pickups.
71 delta88guy is offline
Old February 19th, 2021, 04:07 AM
Matthew Saliba's Avatar
So sorry. I am new to this and not sure how to creat my own thread.
Matthew Saliba is offline
Old February 19th, 2021, 06:14 AM
'70 4-Speed W Machine
tnswt's Avatar
May I suggest this Robert Dana video. He offers advice on how to close an oil pan to avoid leaks. In this video he is using a 400 engine, but you should still find it a great visual.
tnswt is offline
Old February 19th, 2021, 07:33 AM
Thank you. It was helpful but I see he did the gasket on the block I will need to do it on the pan as the engine will be in the car if that is possible. What will I need to remove to get access to the oil pan to drop it.
Old February 19th, 2021, 01:22 PM
Guy Fillinger's Avatar
Matt the easiest!!! The Engine!!!!!!
Guy Fillinger is offline
gbledsoe3
July 12th, 2017 06:29 AM
69CulassConvertible
May 8th, 2016 07:27 PM
Mark57
June 1st, 2015 04:36 PM
twintracks
July 5th, 2014 05:51 AM
Lady72nRob71
April 1st, 2011 05:13 AM
Quick Reply: oil pan gasket sealer?
