Oil coming up through the filler tube
Hi guys,I replaced the Rochester carb with a Holley. I put an oil breather on with the PVC port,now i'm getting oil coming up through the oil filler tube. It's a '64' 394 Starfire motor. Any help? Thanks
You've got pressure build up in the crankcase. Could be your pcv is stuck shut or you have other vent problems. Or could be that you've got worn compression rings and combustion gasses are getting past and into the crankcase. Does the engine run OK? Any loss of power?
