Oil coming up through the filler tube
Old Oct 27, 2010 | 01:29 PM
yopester's Avatar
Hi guys,I replaced the Rochester carb with a Holley. I put an oil breather on with the PVC port,now i'm getting oil coming up through the oil filler tube. It's a '64' 394 Starfire motor. Any help? Thanks
Old Oct 27, 2010 | 02:01 PM
Railguy's Avatar
Did you do away with pcv? Definitely got crankcase pressure.
Old Oct 27, 2010 | 09:13 PM
yopester's Avatar
Just replaced the original pcv with the oil breather pvc.
Old Oct 31, 2010 | 06:31 AM
philnjean's Avatar
You've got pressure build up in the crankcase. Could be your pcv is stuck shut or you have other vent problems. Or could be that you've got worn compression rings and combustion gasses are getting past and into the crankcase. Does the engine run OK? Any loss of power?
Old Oct 31, 2010 | 09:38 AM
Funkwagon455's Avatar
Do a hot compression check, look for low numbers and listen/feel for air escaping the fill tube.
Old Nov 1, 2010 | 08:13 AM
yopester's Avatar
The engine runs good,no loss off power. Thanks
Old Nov 1, 2010 | 08:14 AM
yopester's Avatar
Thanks,will do.
Old Nov 15, 2010 | 06:11 PM
yopester's Avatar
I ended up going back to the old PVC and found another vac.port to plug into,problem solved,just doesnt look as cool!LOL
Old Nov 16, 2010 | 06:34 AM
Railguy's Avatar
Thank for letting everybody know,I hate it when every body offers advise then we never here the out come or what the problem was.
Thanks again railguy
Old Nov 18, 2010 | 09:46 PM
yopester's Avatar
Thank you guys. I'm still going to do the compression test on it,but that will be done in the spring time.
blunce
Jul 23, 2014 07:41 PM
Theo's '67
Jun 7, 2011 11:43 AM
ctrain22
Jul 29, 2009 10:46 AM
68Tom
May 24, 2009 12:53 AM
54olds
Sep 4, 2008 07:15 PM
