Is a Nodular Iron Crank unusual in a '72 455?
Old Mar 7, 2009 | 07:07 PM
cts-v's Avatar
I pulled the oil pan on my '72 455, and was suprised to find a Nodular Crank. I though those were used on the '68 to '70 engines? Was it fairly common on a '72 as well? Came out of a Vista Cruiser.... Thanks. Tom.
Old Mar 7, 2009 | 07:27 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Pretty common crank.
While the pan is off, pull the #4 main cap off and inspect the bearings and crank. That's usually the worst one. Retorque it in the exact same position to 120 lbft
Old Mar 7, 2009 | 07:41 PM
cts-v's Avatar
I did actually pull the #4 cap (just picked one at random). Crank looks nice. A little wear on the ends of the bearing. I'm planning to replace all the crank and rod bearings. Not sure about the cam bearings. Will the cam bearings survive in the hot tank (or whatever cleaning procedure)?
88 coupe's Avatar
Junior Member
Originally Posted by cts-v
........ was surprised to find a Nodular Crank ........
They were all nodular iron. The "N" shows it was cast on the night shift.
Norm
Old Mar 8, 2009 | 07:26 AM
Bluevista's Avatar
Registered
It says in the Olds FAQ crankshaft I.D. Wiki that the 455 crank could be nodular iron or plain iron and that the N means nodular? Is it also in need of correction?
http://www.oldsmobilewiki.com/index....entification_2
Old Mar 8, 2009 | 08:36 AM
Scotty B's Avatar
No, No, No, come on guys, everyone knows the N stands for Norm, or Nightshift, or Norm's Nightshift.
Old Mar 9, 2009 | 09:17 PM
88 coupe's Avatar
Junior Member
Originally Posted by Bluevista
........ Is it also in need of correction? ........
It is.
Norm
Bernhard
Nov 24, 2022 09:12 AM
StickW31
Feb 8, 2015 10:52 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
VITO
Jun 26, 2007 09:34 AM
