No Fuel to the Carb!
Hi Guys,
I have a fresh rebuilt Q-jet on my new engine. When i pour gas in the vent tube the car fires up until it runs dry. I pulled the inlet hose downstream of the pump and it is squirting fuel. Seems to be past that is the problem. I really don't want to tear into the carb. Anything I'm missing?
Craig
Craig
Craig,
Try pulling the filter out of the carb and see if by chance it was installed backwards. If it is in correctly, does it have fuel on it? If so, try tapping on the carb where the needle/seat may be to see if the needle could be stuck. Or instead of tapping on the carb, get the car over to Los Angeles and maybe the earthquakes will shake it loose.
Brian
Brian
RAMBOW
Jul 30, 2013 03:40 PM
1965cutlassragtop
Jul 15, 2012 06:26 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
