new holley carb
It's a good in between chokeless steet/strp carb:
http://static.summitracing.com/globa...99r10319-1.pdf
How open are your primaries on the fast idle screw ? I had a severe rich idle with a holley I cracked open the secondary idle screw that's under the base and closed up the primary a bit and that did the trick. If you have too much of the transfer slots open you will get a rich idle due to the carb thinking it's transitioning instead of idleing so it dumps unneeded fuel. Before I found this out I used drilled throttle plate on a quick fuel carb I also ran in the past.
ohiocutlassparts
December 10th, 2013 02:54 PM
