new holley carb
Old Aug 17, 2013 | 09:33 PM
brandon 455's Avatar
new holley carb
I just recently purchased a Holley 750 street hp. I was wondering if anyone could tell me about this carb?
Old Aug 18, 2013 | 06:30 AM
It's a good in between chokeless steet/strp carb:
http://static.summitracing.com/globa...99r10319-1.pdf
Old Aug 18, 2013 | 07:30 AM
I noticed it had screw in air bleeds. Which one is for W.O.T and which one is idle?
Old Aug 18, 2013 | 09:57 AM
Old Aug 18, 2013 | 01:12 PM
TripDeuces's Avatar
This may help
Old Aug 18, 2013 | 06:45 PM
So its saying that I shouldn't have to change the air bleeds. I have a rich idle. What else can I do to help this out?
Old Aug 18, 2013 | 07:41 PM
What are all your settings, timing, idle speed, how many turns out on the A/F mixture screws, how much vacuum, where is your vacuum advance plugged into...?
Old Aug 18, 2013 | 07:47 PM
coppercutlass's Avatar
Chevy budget Olds powered
How open are your primaries on the fast idle screw ? I had a severe rich idle with a holley I cracked open the secondary idle screw that's under the base and closed up the primary a bit and that did the trick. If you have too much of the transfer slots open you will get a rich idle due to the carb thinking it's transitioning instead of idleing so it dumps unneeded fuel. Before I found this out I used drilled throttle plate on a quick fuel carb I also ran in the past.
ohiocutlassparts
Dec 10, 2013 02:54 PM
csouth
Jan 29, 2013 08:24 AM
coppercutlass
Mar 25, 2012 03:21 PM
