Need help concerning bolt size power steering pump bracket
Old Jun 13, 2023 | 07:22 AM
SRV8's Avatar
Hi I nee Need help concerning bolt size power steering pump bracke side of engine BB 1971.
Please see pictures
Is this a special bolt like the on on 2. picture, ​​​​​​ or normal bolt / which size and thread has it ?
Thank you very much, greetings from Germany
Old Jun 13, 2023 | 09:55 AM
BillK's Avatar
It should be a normal bolt. You can measure yours to be sure but the one block I have here is 7/16 x 14 thread size. Some applications use the little spacer and some do not.
Old Jun 13, 2023 | 06:21 PM
Bill is correct. That is UNC coarse thread 7/16"-14. All 1971 Oldsmobiles except the Toronado use the thick spacer in Bill's photo. If you omit the spacer, the PS pulley will not line up. On the Toronado the differential bracket replaces the spacer.
jjokrm
Jan 14, 2026 06:46 PM
SRV8
May 31, 2022 08:48 AM
Gerald Nickels
Nov 20, 2021 09:30 PM
rippinbyu
Jun 27, 2021 07:35 PM
marzgtp1
Mar 31, 2008 06:29 AM
