near naked
Captain of my ship
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
Well I got the block and engine bay just about stripped. I am debating on if I will pull the distrbuter shaft and or the carb.The dist I will try to mark where it is lined up so it's not screwed up when it's put back in. The carb I will have to undo the throttle cable linkage , at what point i have not really checked out yet. I need to go to U.A.P. Auto to see if I can get the gaskets I need. So far I have no problem with Valve cover and manifold gaskets which i have. I need waterpump and thermostat gaskets and a thermostat since there was not one in it? The last motor I took apart was back in 1975 with the help of a mechanic friend of mine , so any advice is appreciated. The motor works well so I only plan on cleaning and painting everything. Should I leave the carb. alone and work around it?
naked
Wolfman, I would go a bit farther and pull the engine you are almost there, I would replace the oil pump,"freeze plugs" timing gear and chain, valve stem oil seals,water pump and fuel pump,all gaskets as well, then a visual inspection of the underside of the block as well as the valve train.This a good time to replace the motor mounts, yep one thing leads to another.
Then flush and reseal the trans and replace the filter as well as a visual inspection. Besides, being out will allow you to do a much better job of cleaning and then painting. Oh yea did I mention, one thing leads to another ?
"is there no end to this madness"
Captain of my ship
one thing to another
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
Looking good.
When you had the fuel pump off did you feel inside to see if the timing chain was loose? It will flop back and forth and push way in if it's worn in there. Those timing gears were famous for going bad and were replaced routinely so who knows? My late good buddy was a 60-70's Olds mechanic and the first thing he did when he saw my engine was have me pull the fuel pump so he could check the chain, it was real bad.
I can relate with your medical problem and see how you don't want to get too carried away, surprised you've done as much as you have. I wouldn't do any more than absolutely needed either if the engine was fine before.
![Stick Out Tongue](https://classicoldsmobile.com/forums/images/smilies/tongue.gif)
My chain and sprocks were supposibly replaced before I bought the car, but by the same shop that installed the cheesy 1 yr water pump that failed after 1 year, one month. Who knows...
I don't know if this would work or not. but, maybe you could remove the last 4 bolts on the timming cover and pull it out enough to rotate it. then you could at least take a look at the top timing gear
Captain of my ship
fuel pump
Looking good.
Captain of my ship
![Smile](https://classicoldsmobile.com/forums/images/icons/icon7.gif)
I will check that possability tomorrow when I get back to the garage , thanks
