My New 394 on Dyno
Old Oct 27, 2019 | 06:51 AM
KQQLCAT's Avatar
My New 394 on Dyno
Well I finally got my new 394 from Ross Racing. Here's a picture of it on the dyno.
Old Oct 27, 2019 | 06:59 AM
61Bat's Avatar
Awesome! Video? Specs? Dyno charts? Dont tease us like this!!
Old Oct 27, 2019 | 08:00 AM
67OAI's Avatar
Old(s)GuysRule
More! More! Do you have a video, with sound of course, of it on the dyno?
Old Oct 27, 2019 | 10:20 AM
OLDSter Ralph's Avatar
YEEHAW !!!!!!! I look forward to hearing it run, the next time I see the car.
Old Oct 27, 2019 | 10:37 AM
Kennybill's Avatar
Hmmm, any problems dealing with Ross Racing Engines? Just curious. Nice looking engine. Will be looking for more information. Thanks
Old Oct 27, 2019 | 02:10 PM
69HO43's Avatar
Pic might be from 6 years ago...or may not be.
Hope your numbers are better than 340.
Old Oct 28, 2019 | 01:36 AM
Vern's 63 Starfire's Avatar
Yep and here’s mine on the dyno!! All 340 HP according to Tony! Suppose to be a complete 1963 engine. Mine has fuel pump block off plate as well. All 13K + worth that’s not in my possession yet
Old Oct 28, 2019 | 04:18 AM
Charlie Jones's Avatar
Phantom Phixer
That's not a 1963 engine . Look at the timing cover and water pump .
This is a 1963 engine ;
Old Oct 28, 2019 | 04:34 AM
Charlie Jones you are exactly correct. Tony with Ross Racing Engines has been building a complete 1963 394 for me since November 2013. $6500 down in 2013 and received the pic I posted from him last week saying that was my engine on the dyno.
Old Oct 28, 2019 | 05:43 AM
KQQLCAT's Avatar
I tried to load it running on dyno but it won't load.
Old Oct 28, 2019 | 05:50 AM
KQQLKAT,
Let’s see your dyno sheet, build sheet and by the way when did you order your motor and was it on your core?
Old Oct 28, 2019 | 05:55 AM
KQQLCAT's Avatar
He said it would be around 425HP ended up being 415HP
Getting engine ready to go in.
Old Oct 28, 2019 | 10:08 AM
Kennybill's Avatar
415 hp, is a good number for a streetcar. It's none of my business "but" what was the time limit between delivery and pick up of your engine? Without of quoting $numbers, was the engine final $$ near your estimate? Being an Olds guy and living nearby to Ross, I've always spoke well of Ross and have recommended him to Oldsmobile owners. As of lately, I'm not recommending Ross. I'm a big fan of the 1961's, love the post, love the roof. Beautiful car.
Old Oct 28, 2019 | 12:49 PM
KQQLCAT's Avatar
It took a little over a year and I drove down to get it. It was exactly what he quoted.
Old Oct 28, 2019 | 05:00 PM
Phantom Phixer
That ought to make that old '61 two door FLY ! You do have a posi unit in it don't you ?
Old Oct 28, 2019 | 05:14 PM
oldsmoboogie's Avatar
Awesome! Care to share the specs? Compression ratio, cam specs, any head work done?
Old Oct 29, 2019 | 06:42 PM
rickw30's Avatar
Originally Posted by Vern's 63 Starfire
Charlie Jones you are exactly correct. Tony with Ross Racing Engines has been building a complete 1963 394 for me since November 2013. $6000 down in 2013 and received the pic I posted from him last week saying that was my engine on the dyno.
Did I read this correctly ?!
6 years. Holy Sh** ... You are a patient man.
Old Oct 30, 2019 | 11:15 AM
rocketraider's Avatar
Oldsdruid
There were reasons the 60s Gasser crowd loved the 394. Unfortunately they loved them so much they used 'em almost all up!
Old Oct 30, 2019 | 04:00 PM
Yes Sir!! You did. !! When I went to get it though Tony treated me like I was trash. He acted like I had only given him a week to build it.
Old Dec 4, 2019 | 03:57 PM
61Bat's Avatar
Updates? Both from KQQLCAT and Vern.......please.
Old Dec 14, 2019 | 06:46 AM
KQQLCAT's Avatar
Well it's in and has been started but it's too cold out to test. Exhaust was too strong in garage so I put it to sleep for winter. Exhaust is louder now didn't expect that. Must be because it now has 10:25 to 1 compression. Also I put in a new Power master Alternator generator.
Old Dec 14, 2019 | 10:18 AM
RandyS's Avatar
Sweet!
Old Dec 14, 2019 | 11:44 AM
Pat, what rear end and ratio are you running ? Did you need a core for the alternator/generator? Engine looks good except for the color.
Old Dec 14, 2019 | 01:18 PM
61Bat's Avatar
Looks great! Where did you find the fan shroud?
Old Dec 14, 2019 | 03:46 PM
VORTECPRO's Avatar
Can you post up the dyno test data?
Old Dec 15, 2019 | 06:17 AM
KQQLCAT's Avatar
2:78 Fabcraft posi unit, and no you just buy the alternator but the upper bracket has to be fabbed. Color?
Old Dec 15, 2019 | 06:23 AM
KQQLCAT's Avatar
Came with car when purchased.
Old Dec 20, 2019 | 06:13 AM
KQQLCAT's Avatar
Here is a picture of the roller rockers he put on. He manufactures them.
Old Dec 20, 2019 | 02:05 PM
61Bat's Avatar
These fit under the stock valve covers KQQLCAT? Are you running a custom grind cam as well? Was any port work done to the heads? Are you going to chassis dyno the car? AAAhhhhh.....so many questions!!
Looks great though and I'm glad you are sharing this.
Old Dec 21, 2019 | 06:59 AM
KQQLCAT's Avatar
Yes the stock valve covers fit. Probably won't chassis dyno it with 2:78 gears in the rear whats the point. Has a roller cam and lifters so it's a custom grind cam but not extreme I wanted it to be streetable.
Old Dec 21, 2019 | 07:03 AM
  #31
KQQLCAT's Avatar
Old Dec 22, 2019 | 03:02 AM
  #32
oldolds88's Avatar
fourth push rod on the right doesn't look like its setting right
Old Dec 22, 2019 | 10:09 AM
  #33
KQQLCAT's Avatar
Rockers weren't on yet I just wanted to show you guys the lifters.
INTRUDER
Dec 19, 2019 01:36 PM
sborruso
Aug 4, 2008 03:54 PM
Sangersam
May 14, 2008 08:28 PM
olds59
Feb 5, 2008 09:17 PM
