my 455 was scrap ... so I'm getting this lot tomorrow ...
Old Nov 15, 2007 | 05:49 AM
Aussie67Delta88Custom's Avatar
Greeting from Australia.
I own a 67 Delta 88 Custom that we thought was running a 425, but on dismantling the engine the reconditioning guys found it was a 455 ... and that it was too far gone to recondition.
As you can imagine, oldsmobile motors aren't just "on the shelf" in the Land Down Under so I was faced with having to take the 425 out of a 66 Delta 88 coupe I had bought for it's motor... but once I recieved it I did not want to pull it apart.
Luckily I stumbled across someone selling pistons for a 455 on Australian Ebay so I emailed him to ask what else he had and the answer was ... A whole 455 motor in the middle of being reconditioned !
For your opinion, here is the list of what is with it...
Block & main caps(Acid cleaned)Bored & Honed +.040",
Crank,
Conrods(polished & shotpeened)
2 Sets +.040"Piston & Rings,
Camshaft(Crow 651 Regrind) with New cam bearings,
Rollmaster 9 keyway timing set,
Original-Alloy Intake Manifold (!),
Oil pump/pickup & shaft,
Harmonic Balancer,
timing cover,
Sump,
Heads with valves(2.060"In 1.650"Exh.)
Set New double valve springs/Retainers & collets,
Also Chromed- Rocker covers,front pully, timing Tab,Oil filler Neck,
Starter motor, Distributor.
What do you guys "in the know" think about these bits ?
I pick it all up tomorrow night and look forward to driving the car with this 455 in it.
thanks for looking at my thread
Gary Thorpe
Oldsmobile club of Australia.
brandon reynolds
Aug 20, 2019 09:22 AM
Dead Reckon
Feb 13, 2015 09:11 AM
scooter123
Mar 12, 2012 01:07 PM
wjustinmartin
Jan 15, 2010 11:58 AM
jensenracing77
May 21, 2009 06:50 PM
